Arkluvs2fly
I'm New Here
During my annual inspection, we (my daughter - an A&P - and I) were installing new tire and discovered that the left main strut was VERY loose. Once we began removing it, we noticed a stripped bolt head (the nut was completely off the bolt and a couple of bolts were bent. I have posted these but don't know if you can see the slight bend in the bolts. I did not build this aircraft and it appears that the bolts were over-torqued. Reading the build manual indicates that this can happen. The manual also states to check the bolts (inspect and torque check) at annual and every 50 hrs. I was lucky we found this before a nasty little incident occurred...
