Thoughts for yaw indication at high AOA and negative AOA of high magnitude? The old school turn needle is the only way to reliably see yaw in a spin. You wouldn’t need a TN per se but something that is yaw only and does not include roll rate in any fashion.
The dynon gives me lateral G - that is what I am displaying for the skid slip ball - does that work?
Start Char|Width|Description|Notes
1 2 Hour 00 to 23, current Zulu time hour according to EFIS-D10A’s internal clock.
3 2 Minute 00 to 59, current Zulu time minute according to EFIS-D10A’s internal clock.
5 2 Second 00 to 59, current Zulu time second according to EFIS-D10A’s internal clock.
7 2 Fractions 00 to 63, counter for 1/64 second. Data output frequency.
9 1 Pitch Sign ‘+’ or ‘-’ (positive means aircraft is pitched up).
10 3 Pitch 000 to 900, pitch up or down from level flight in 1/10 degrees (900 = 90o).
13 1 Roll Sign ‘+’ or ‘-’ (positive means aircraft is banked right).
14 4 Roll 0000 to 1800, roll left or right from level flight in 1/10 degrees (1800 = 180o).
18 3 Yaw 000 to 359 in degrees (000 = North, 090 = East, 180 = South, 270 = West).
21 4 Airspeed 0000 to 9999, airspeed in units of 1/10 m/s (1555 = 155.5 m/s).
25 1 Altitude Sign ‘+’ or ‘-’ (positive means altitude is above sea-level).
26 4 Altitude 0000 to 9999, altitude in units of meters; alternates between pressure and displayedaltitude, depending on status bitmask, starting at character 42. 30 1 Turn Rate/VSISign‘+’ or ‘-’ (positive means aircraft is turning right). Alternates between turn rate and VSI sign, depending on status bitmask, starting at character 42.
31 3 Turn Rate or VSI Alternates between turn rate and VSI, depending on status bitmask, starting at character 42. When turn rate, 000 to 999, 1/10 degrees/second rate of yaw change. When VSI, 000 to 999, 1/10 feet/second.
34 1 Lateral g’s Sign ‘+’ or ‘-’ (positive means aircraft is experiencing leftward lateral acceleration).
35 2 Lateral g’s 00 to 99, lateral g’s in units of 1/100 g (99 = 0.99 g’s). Appendix
37 1 Vertical g’s Sign ‘+’ or ‘-’ (positive means aircraft is experiencing upward vertical acceleration).
38 2 Vertical g’s 00 to 99, vertical g’s in units of 1/10 g (99 = 9.9 g’s).
40 2 Angle of Attack 00 to 99, percentage of stall angle.
42 6 Status Bitmask A 6-character ascii-hex field representing a 24-bit status bitmask. When the value of bit 0 (LSbit) is 0, the altitude field is displayed altitude, and turn rate is output in characters 30-33. When the value of bit 0 is 1 the altitude field is pressure altitude, and VSI is output in characters 30-33.
48 2 Internal use Internal use – ignore
50 2 Checksum The ascii-hex 2 byte sum of all 49 preceding bytes.
52 2 CR/LF Carriage Return, Linefeed = 0x0D, 0x0A.
Example: "00082119+058-00541301200+9141+011-01+15593EA0C701A4<CR><LF>""
