Joe Mckamey
When reading the line maintenance manual it says that cleaning the oil tank is optional, but if you do it, you must purge the oil system. I have read a couple posts from 2020 where people said that you can clean the oil tank without purging the system. You would just have to keep the OUT line elevated to prevent air from getting into the system. At least this is what I gathered from the video being shared there which I will also share here.
We are about to change the oil again at the 200 hour Tach time on the engine. We’ve been changing it every 50 hours since 44 Tach.
This 912iS engine was ran with 100LL for the first 44 hours and we have been running strictly 91 Octane since then as that’s when we bought the airplane from Tango Flight (high school build program).
If you read the attached instructions for cleaning the oil tank, it says optional, and most importantly do it at the 200 hour mark if you’ve been running 100LL. It also says that you must purge the oil system which seems rather involved.
Trying to do everything correct here without causing too much work. Can I get some seasoned guidance on whether I can clean this oil tank without having to purge the system? TIA
