I’m installing a Dynon heated pitot in my RV-14A. I’m at the point of testing it before buttoning things back up. The probe heats up fine. I’m using an indicator light ( not LED) that uses .07 amps while lit. I’m quite sure this indicator came with a B and C alternator , for its indicator.
With ships power on and power going to the indicator light and the white wire from the pitot connected to the other side , the indicator is not lit as it’s supposed to be. Turn on power to the pitot and it heats up. Turn pitot heat off and the indicator is still not coming on. Remove the white wire from the indicator and provide ground, the indicator illuminates.
Ideas as to what I have wrong?
Thanks Ron
Thanks Ron
