chris1seto
Admittedly, no not yet......
Do you have a specific location in mind and have you seen one installed there on a -10? The challenge is that the firewall and space behind the engine is absolutely packed with stuff. Fuel lines, oil lines, oil cooler, hose for the heating system, etc. For me, it was a chore getting everything in there AND leaving room to change the oil filter, access the mags, etc.
I've seen a number of builds do it, and my build is simple FWF (no AC or EFI) so I wasn't too worried about space. My engine still isn't here yet so all I've had to go off of is other build logs.
I was thinking it would go about the same height, opposite side as the oil cooler.
At least the good news is that if it doesn't fit FWF, I have a shot at putting it just aft above the pedals. I've seen that location work too.
