Loctite 8151 Silver Grade Anti Seize equivalent
Best I can come up with and not wait a week for delivery is Permatex anti-seize 81464. Any thoughts on using the Permatex? This is for the sprag clutch and housing whilst replacing the stator and ignition housing.
Try Bostik Never-Seez Pure Nickel Special Anti-Seize
At the airlines this is the go-to for anti seize. Designed to use inside jet engines. I filled a large syringe 20 years ago. I have used it on every aircraft & automotive project. No complaints.
temperature range of
-297°F to 2,400°F
Another alternative, often available locally, is Loctite LB8023 Marine Grade Anti-Seize:
Thanks for the suggestion. That alternative appears to be metal-free; not sure if that would work. I'm researching whether Permatex anti-seize 81464 is an equivalent.
You might check to see if Roger Lee in Tucson has some in his shop:
Roger Lee
LSRM-A & Rotax Instructor & Rotax IRC
Tucson, AZ Ryan Airfield (KRYN)
520-349-7056 Cell
