I'm following the excellent thread on setting the low-pitch static stops to prevent overspeeding, and heading to the airport tomorrow to make that adjustment. I have a suspicion that my governor (an MT 860-4 on a Hartzell CS blended airfoil propeller) may not be configured exactly correctly for my aircraft - the maximum RPM adjustment screw is bottomed out, and right now, that sets max RPM at 2800 - too high! That concerns me, as it's not an easy fix (the MT Manual says moving the arm on the governor has to be done by a service center), but it also makes me wonder if the low end of my governor is similarly askew, and low RPM isn't something I've seen addressed here.
What is the lowest RPM that I should be able to set with my prop lever, and how do I check that this is set correctly - i.e. what flight profile?
