I’m installing SDS coil packs.
How do people split up the top and bottom plugs between the coil packs? Does it matter?
Option 1:
Right coil pack does all top plugs
Left coil packs does all bottom plugs.
Option 2 (which I think? Is how mags are setup?)
Left pack - 1 & 3 top plugs, 2 & 4 bottom plugs
Right pack - 2 & 4 top plugs, 1 & 3 bottom plugs
How do most people orient the coil packs on the mag holes?
I was thinking that pretty much they would only fit with the coil packs oriented outboard - but this means the left coil pack plug would be facing up? (Water ingress)
This has the advantage of the bottom plug positions on each coil correspond with the bottom plugs on that side of the engine (the top plug positions on the coil are reversed, so the top leads would have to cross over to the opposite side of the engine)
A pic below of outboard orientation of the coil packs, and a couple of rudimentary drawings of the question i’m poorly trying to get across!
Option 1:
