I have two older GRT Horizon WS units I'm not sure if they will workAre you ‘married’ to Garmin? Both Dynon and GRT EFIS units can control a remote mounted Trig TT22 mode S transponder (the Dynon transponder is a re-branded TT22). The TT 22 can ‘read’ the data from Garmin TSO’d gps boxes, and is remote-mounted - no panel space needed. If you want a panel control box, it fits in a 2 1/4” hole. Trig also makes the TT31 rack mounted transponder. Sized to replace King KT76, I don’t know the dimensions. Finally, Trig just announced a TT23, upgraded TT22, which I know nothing about.
The GTX 335 or 345 is the same size panel opening but a bit longer than the 327.Does Garmin make a replacement transponder for ADSB that I ca simply replace what I have that will fit in the existing spot? Im having issues with my Uavionics and would be nice to just remove and replace. Thx
I think you need at least a 2010 Hx to get the remote transponder control….I have two older GRT Horizon WS units I'm not sure if they will work
GTX335 WAAS.Does Garmin make a replacement transponder for ADSB that I ca simply replace what I have that will fit in the existing spot? Im having issues with my Uavionics and would be nice to just remove and replace. Thx
That is what I do in my -8: Garmin GTX-327 transponder and a Garmin GDL-82 for ADSB-out (UAT 978). The GDL-82 also allows you to use the transponder in anonymous mode to mask your aircraft ID. I already had a 327 when I did my panel upgrade so I just kept it and got a GDL-82 from someone here on the forum.You can also keep your GTX-327 if you install a Garmin GDL-82 in-line with your transponder antenna cable for your ADS-B-Out UAT solution. And, you can also use a Garmin GDL-50R for an ADS-B-In combined UAT / ES receiver solution. Even though Garmin no longer makes the GDL-82, someone is always selling a GDL-82 up on Ebay at any given time (4-units up there right now on Ebay). Otherwise, if you need or want ES for your ADS-B-Out, then you probably need to mount another tray and rewire a cable for something more like a GTX-345. I use the GDL-82 (Out) and GDL-37 (older version of the GDL-50R) solutions myself, and it's been working perfectly since 2019.
