<sigh>
The fuel drain flange, VA-112, on my Left QB Tank circa 2015 (Philippines), decided to spring a leak and ruin my high-$$$ paint job
And, pressurizing the tank slightly and spraying a mixture of soapy water on the flange revealed the end of the leak path:
Looking inside the tank, it appears that all the rivet tails are neatly encapsulated in "pro seal"...
I suspect the source of the leak is the flange-to-skin interface at the top of the NPT annulus..
I'm looking for ideas/options on how best to fix, here's all I've come up with...
1. Drill out the 6 rivets, pop off the flange and clean the mating surfaces. Upsize the holes to #30, countersink flange holes to 120° and install AK-42H "tank" rivets with a generous application of "Proseal" between the skin, flange, rivet bodies, my skin, hair, fingers, wheel pants, refrigerator handle...
2. Apply a slight vacuum on the tank and apply "thin" sealant to the leak path; glue the channel shut? Which sealant works here?
3. Other ideas?
Thanks in advance y'all.
3. Other ideas?
