I searched, but didn't see an answer to this. I understand Lane B must be on to monitor the OP on the Garmin EFIS during the Rotax oil purge procedure (sensor connects to B). This would seem to also have ignition B on, firing half of the plugs when the prop is spun. Because either the bottom or top plugs are removed from the cylinder, should those plug leads be grounded, left open, or left hanging with the plugs inserted and threads grounded so they can fire? Youtube videos seem to assume a manual OP gauge, so this isn't addressed. I'm not sure if the Rotax ignition modules care if they are open circuit or grounded, and exactly which plugs are fired by Lane B.
