I PROMISE I’ve used the search function: here is my problem. No mounting hardware came with the governor. The instructions say follow the engine manufacturer. FOR THE LIFE OF ME I can’t find that in lycoming literature. Probably because they don’t support experimental like that. So I called van’s and they said use what is on the block holding the blanking plate on. So then digging through random bolts, nuts, ect supplied with the engine I can find the same items (but new) that are holding the blanking plate on. Great. HOWEVER I don’t love this. First off, why not use a metal locking nut (I know better than to use nylon in the engine bay) but a metal nut seems smarter than a locking washer. Also the locking washer is ever so slightly larger than the stud so it clocks a bit off. If this is what everyone does, I’ll go along with the tried and true method, but is this really how ever is mounting govenors?
