I had a VDO oil pressure sensor that occasionally acts up. I tried replacing it with a new Dynon pressure sensor for 150psi. It was hard enough getting one that is part number 105492-002. The problem is I didn’t notice the note on stein air that it is not compatible with legacy D180. I found that out the hard way ground running with this sensor. I could not get an accurate reading. I installed the 6.8 Ohm resistor. I toggled through sensor type 5 or 1-5 and none displayed correctly.
Part number 103757-000 is on the Kavlico Dynon Addendum for D180 installs. Why can’t I find these for sale anymore? Anyone else have this problem? Why isn’t the currently sold probe by Dynon compatible? Attached are pics of the new probe and the addendum part numbers.
