Quick Build Fuselage Corrosion on Bolts and Nutplates
danlh
I'm wondering what to do about some corrosion that I found on some nutplates and bolts on the interior of my QB Fuselage.
Is this something that should be replaced?
I’d think about the risk of failure in flight or while landing, and ease of inspection. I’m no corrosion expert but I’d think also about surface vs structural issues. Does scotchbrite and oil fix it? If so I wouldn’t remove all those nutplates.
You can start or add it to a list of things to re-inspect every time you tear down to look in Phase 1, and at least every 100h after. Hopefully this list includes other areas where the structure isn’t perfect or you modified from plans.
There were certainly people out there who made mods or ignored problems and didn’t look before it was too late. Just don’t be one of them. Look. My 2c. Someone with knowledge of steel corrosion might look and say “replace!” I’m waiting to see if that happens. If it were aluminum I’d scotchbrite or sand and then polish it off and protect with primer.
I’d replace the hardware, not that difficult or expensive
I’m in Bill’s camp.
The most difficult part about installing nut plates is drilling them and countersinking and that is done.
Drill the tails off the rivets as you’re not trying to save the nut plates. Use a drill stop and don’t go deeper than the tail is tall.
I would be curious to see if there is any corrosion under the nut plate or heads and shaft of those bolts.
Thanks for all the replies. I’m leaning towards replacing the bolts and see if I can clean up the nut plates. That spot sand blaster looks interesting!
I hit the bolts and nutplates with LPS2 spray. Some people dislike the idea or spraying lubricants inside their plane because it attracts dirt, but the light coating of oil will hopefully keep the nuts and bolts rust free. Other people also hate the idea of cleaning off lubricants residue before painting.
I would be careful with using a blast media even at a focused area. You will have some abrasive to clean up, no way to keep it refined to just the nut plate. It will go through the nut plate hole. You will also be faced with priming the areas around the nut plate and the nut plate.
Sounds like a lot more work than simply replacing them to me with a lot of questions on how this will even work.
Regardless of their marketing, spot sandblasting has been around, well, since blasting has been a thing.
How long ago did you get your QB Fuse? Asking because mine should show up after the first of the year around the beginning of March.
No dog in this fight, but to add to Lester's question, where was that QB fuse stored ?
Curious as I have loads of hardwear, bolts, screws, platenuts (nutplates ?) etc, that are in bins or laying around on a shelf in the hangar and some of them are 10 -13 years old.
No trace of any corrosion.
Your's seem to be a unique, if not freaky occurance...
Good luck
I had exactly the same on my QB Fuse, I emailed Vans and they told me to replace the hardware. The nutplates clean up easily with a stiff nylon brush and I've bought replacement nuts and bolts. After I received my QB Fuse I had stored it in the unopened crate inside a shipping container for 9 months which I assume caused this issue on mine.
Good luck
The fuselage has been stored in the hanger. I uncrated the day I received it.
I plan to replace the bolts and nuts. Their also showing some corrosion.
I'm disappointed that I am going to have to disassemble most of the parts around the spar and gear attachment supports.
"After I received my QB Fuse I had stored it in the unopened crate inside a shipping container for 9 months which I assume caused this issue on mine."
Sorry to hear of this. It has been some of my experiences that parts should not be stored in a closed wooden crate. For extended periods of storage, the wooden crate should be open to allow the moister from the wood to escape.
