Holy cr*p
Very few "aircraft grade" bolts in Lycoming's. Most are Lycoming bolts, whatever they may be.Great outcome! As others echoed, I bet the crank dowel pin experienced fatigue and SB 475c wasn't properly accomplished. How many hors ago was the prop strike? Or when was the prop replaced?
Another reason for making sure those prop low pitch stops are set correctly (about 2650rpm static). Even if you tried to pull the prop back, in your case with no oil pressure, nothing would have happened, as you need oil pressure to coarsen the propeller. So don’t second guess that you didn’t do it.. wouldn’t have made a difference. Great job with the landing!
I was told at Lycoming school years ago that most of the external case bolts are simply Grade 2. Internal, highly-stressed “Jesus bolts” ….I only buy them from Lycoming because of…..superstition?Very few "aircraft grade" bolts in Lycoming's. Most are Lycoming bolts, whatever they may be.
SB475c has you replace the bolt and locking plate but also inspect the dowel pin for signs of damage..Very few "aircraft grade" bolts in Lycoming's. Most are Lycoming bolts, whatever they may be.
Normal.All the connecting rods, however showed a bit of play or wabble on the crank...I don't think they should do that. .
Well done, well written, and welcome to the clubStay safe out there, and fly the plane!!
1. See post #50 in this thread regarding counterfeit "KS" fasteners.That is a grade 5 bolt in your pic, not a cheap offshore ungraded bolt. In fact it looks just like the one lyc sells. The fact that it has a mfg identifier (ks) implies a reputable brand. Home Depot bolts rarely have these. There is no special bolt for that gear. It is lyc part number “std-5/16,” which in lyc terms means a run of the mill grade 5 bolt, possibly grade 2. The higher strength or specialized stuff usually gets a more traditional part number.
What you feel on the rods is likely normal- .003” of clearance, so they can wobble a bit.
thanks. didn't know that and missed that post.1. See post #50 in this thread regarding counterfeit "KS" fasteners.
2. The correct Lycoming crank-gear bolts have a flat head face with the 4 digit Lycoming part-number stamped on them.
Skylor
I was told at Lycoming school years ago that most of the external case bolts are simply Grade 2. Internal, highly-stressed “Jesus bolts” ….I only buy them from Lycoming because of…..superstition?![]()
Interesting. Just bought one for an O-360-A1A and it is a STD-2213, now superceded by STD-2246. That is for the smaller 5/16 bolt on the non CW crankCorrect crank gear bolt-I am finding Lycoming pn 01C26131, verified by both Air Power and Spruce. $91.17 from Air Power.
