Remote controlled tow for the RV-10 with wheel pants.
Aviator
I have been looking and am not finding the answer. Its the end of 2025, surely there is one suitable for the -10.
Or anyone have a home brew soultion?
Should be within reason, cost wise.
Does it work with the standard wheel pants on the nose wheel of the 10? Anyone here use one of these?
Ty, tocketman. I did look at these but no info on whether it will fit.
Thunder volt power tow is what I have for my 6A with nosewheel pants - with the wheel pant extension.
I have mine set up for the nosewheel axle with holes through the pant.
Personally, I have a Best Tug B8 for my -10, so I cannot verify the Romeo series. However, a quick call to Best Tugs will tell you everything you need to know. They are awesome and their customer service is fantastic.
Yeah, I know the B8 is WAY overkill for the -10 but the guy who I shared a hangar with sold his cirrus and didn't need the tug anymore. So I got a practically new B8, already in my hangar, no shipping, no tax for a really good price. Too good to pass up!
Try
They are expensive but worth it. You'll have to call them about fit if not mentioned on the site. I have one for my C180 and it's been totally reliable for at least five years now.
Dave
Try
Dave
I agree that the AC Air tug is a great choice! I made adapters to allow use with my -14 (nosewheel similar to the -10, I think) and it worked flawlessly. No more challenges backing the castering wheel fork and much safer maneuvering the plane when you can really watch the tight spots instead of grunting at the prop.
"Cost within reason"? Of course it’s reasonable. We’re talking about airplanes, right?
I have the AC Air Technologies Tug for my RV10 and it works great. Fits my wheel pant with no problems. If you have your front wheel pant really tight on the sides of the tire you might have to open it a little. I consider mine pretty tight and the clamp goes in just fine without touching the pant.
Is there a specific model inam looking for?
I went to their website and I don't see the model I have. It is called T- Mini. It would be the smallest one they have I think T1V2. My cradle is different than what they offer now. I have had mine for around 6 years. My cradle has arms that pop up on each side and go up under the wheel pant that lock around the front tire. They offer as an accessory constraint arms for the RV10 but I haven't needed them. If you have to negotiate up hill you would need them to keep the tire from jumping out of the cradle. They offer a front roller that might be needed to raise the front tire as the tug nears the wheel pant to slide under the cradle as low as the pant is to the ground. I would call them if you are interested in one as the model that has worked well for me is not listed. They may still have one and they also sell used and refurbished tugs.
I have a best tug, not this product. I fully trust that if you told them your plane when you order that you will get the right stuff.
I did open the hole in my wheel pants though.
