How to best layout for an M1B and 7A combo
I have a M1B, 7A, Elastomeric.
There were a few things I would do differently. Most of the plan penetrations were pretty close. Here's a few that filled the cuss jar.
-Fuel line is crazy close to the output side of the starter relay. Yes, it's only hot during start, but all it takes is one zap. I would relocate the relays a little starboard with a doubler.
-Battery box. OMG! Cut the front off. Install two hinges to hold it on but add a 1/4" of depth. Much easier to R&R the battery and the extra depth comes in handy if a battery is slightly different or swells. I use a section of baffle to take up space and protect the firewall from a short. It's a "T" shaped piece that lives between the battery and firewall. No way for a wire to touch. Also, add nutplates to the firewall. Crazy to have that box, or anything else, mounted with bolts and nuts. Unless you like crawling around under the panel.
-Throttle cable hole could move a little starboard. It goes through the lower corner of the recess.
-Prop governor cable was a bear. Sort of my fault though. I have the RV10 oil cooler with a 4" scat plenum. It hogs up a lot of real estate. Cables had to route around the parts. I wouldn't trade it though. I can manage oil temp easy from stone cold to 200 just by adjusting the butterfly control.
Pressure transducer manifold is fine but works better with a 1/8" shim. Kavlico sensors clear mounted from the side. More clearance in front.
-Dan's insulation works. I used 1/8" Fiberfrax and 0.005" Titanium foil. A few wide stainless pop rivets hold open areas. Cut away so the engine mount is flush to the firewall.
-DoubleTee eyeball pass thrus are great. Expensive but hold cables any orientation.
-Bowden cables, I used the steel AN fitting trick. Heat, Alt Air, Oil Cooler
Probably others. Shoot me a PM if you need more.
