Page 37is/U-09 calls for the MS20257-3 cowl side hinge to be offset 1/16" up from the bottom cowl edge. Doing that leaves 7/16" of leaf overlapping the bottom cowl fiberglass. That allows for 1/4" rivet centerline to fiberglass edge (~ 2.5*Rd clearance) and 3/16" rivet centerline to leaf edge (2*Rd clearance) for the aluminum. That feels uncomfortably tight for that long row of rivets in the fiberglass, and seems like it's just asking for a crack. I've been following N122B's builders log photos, and it looks like Barry has more fiberglass edge clearance. Am I missing something? Substituting -4 hinge would give 1/8" more overlap to work with. Moving the hinge down would also improve it, but then the segments may show at the split.
Edge clearance check: Rivet diam. (Rd) = 3/32; Min. rivet centerline to fiberglass edge = 2.5*Rd = 15/64; Min. rivet centerline to aluminum leaf edge = 2*Rd = 3/16. The sum of those is 27/64, which is just 1/64" under the 7/16" overlap.
