Lycosaurus
I swapped out my power jet nozzle with another one that was drilled to allow more fuel flow, and I thought I had lost the felt gasket (52) at its tip. Checked inside the carb which houses the nozzle section and I don't see anything.
I install the replacement nozzle with a new felt gasket. The copper safety gasket (52) will not seat securely as there seems to be something impeding the nozzle from descending further into its chamber.
I carefully remove the nozzle while looking to catch anything that will fall out from the nozzle chamber. Nothing. I look inside, and it is hard to tell if the gaskets are still there, however probing shows that there is likely several gaskets in there. I try removing them but they are deep in the nozzle well of the carb. I tried poking it, compressed air etc but I am at a loss on how to remove them.
Anybody come across this issue? Any advice? Thanks.
