Marvel Schebler MA4-SPA 10-5217 detailed parts list
Lycosaurus
I was having a hard timing identifying a main jet gasket for my carb. A supplier helped me out and sent me a pdf copy so I could identify other components.
Hope this helps someone else. Also posting this just in case I lose my original in the future.
Note: The Service Manuals identify the components, but do not provide actual part numbers. Yes, this is an older version of the carb with two piece venturi, however the updated part number for the venturi can be easily identified in the Aircraft Spruce Catalog. If you have a more recent parts list, please do post it here.
Thanks for the file. But, it is out of date.... It shows the two piece venturi that has been replaced with a one piece.
MA-4-5, MA-4-5AA Overhaul Instructions
