I have had two oil coolers fail on my new to me IO360 powered RV-4 this flying season now and I am looking for advice on what to inspect/ possibly change.
The first oil cooler was a Stewart Warner 7 row that came on the airplane when I bough it. It looked a little scruffy, but it did it's job well until I put about 10 hours or so on the airplane. Then it sprung a leak at the top "tank" seam in between two of the rows. I replaced it with the same make/ model that was a Drake air overhauled unit that had been on the shelf for several years. I put about 25 hours on this one and it failed in close to the same location, this time leaving me stranded 100 or so miles from home.
For reference, the cooler is mounted to the rear baffle, the AN hoses have plenty of flex and aren't pulling on their fittings at all, and I had the prop dynamically balanced the day prior to the second failure (I highly doubt it is related at all, I just wanted to state that the second one failed after it was balanced). Oil pressure is about 80PSI in cruise and never exceeds redline. Oil temp is consistently around 180F in cruise.
Am I just unlucky or is there a contributing factor that I may be missing?
