This is great information, thank you for sharing. For what its worth, the FSDO Inspector I met with stated that there was no need to modify the Operating Limitations to permit the expansion of the LSRM privileges once MOSAIC goes into effect based on the interpretation I posted. Obviously this contradicts the guidance you were provided. As others have posted, hopefully one of the many advocacy organizations is working to clarify this. Clearly, standardization is needed, and taking the conservative approach in how one interprets these makes sense. It would be great if the 'Washington Level' FAA could issue a document clarifying this internally to the FSDOs and publicly.
The 800 page document referenced does both.
The majority of it is the FAA's preamble stating their position and intent. However, it also includes the final codified regulations, which go into effect on October 23, 2025.
The actual published regulatory changes are towards the end of the document, allowing us to see what exactly the changes to the FARs include come October 23. The 800 page document published is not a 'Notice of Proposed Rulemaking' - it is the 'Final Rule'.
Once change relevant to this discussion is the creation of 65.109, which begins on page 705. I'll try and paste it here with decent formatting as best I can:
§ 65.109 Repairman certificate (light-sport): Privileges and limitations.
(a)
The holder of a repairman certificate (light-sport) with an inspection rating may perform the annual condition inspection on an aircraft:
(1) That is owned by the holder;
(2) That has an experimental airworthiness certificate issued in accordance with § 21.191(g), (i), (k), or (l) of this chapter; and
(3) That is in the same category, and class as applicable, of aircraft for which the holder has completed the training course specified in § 65.107(c) of this part.
(b)
The holder of a repairman certificate (light-sport) with a maintenance rating may
(1) Approve for return to service an aircraft that has a special airworthiness certificate in the light-sport category under § 21.190 of this chapter, or any part thereof, after performing or inspecting maintenance (to include the annual condition inspection and the 100-hour inspection required by § 91.327 of this chapter), preventive maintenance, or an alteration (excluding a major repair or a major alteration on a product produced under an FAA approval);
2) Perform the annual condition inspection on an aircraft that has an experimental airworthiness certificate issued in accordance with § 21.191 (g), (i), (k), or (l) of this chapter; and
(3) Only perform maintenance, preventive maintenance, and an alteration on an aircraft that is in the same category, and class as applicable, of aircraft for which the holder has completed the training specified in § 65.107(d) of this part. Before performing a major repair, the holder must complete additional training acceptable to the FAA and appropriate to the repair performed
The above is part of the final rule of 65.109, and becomes effective on October 23rd, 2025.
This is spot on. A&P Mechanics are certificated under Subpart D of Part 65, titled "Mechanics", whereas LSR-Is and LSR-Ms are certificated under Subpart E of Part 65, titled "Repairman". A Repairman is
not a Mechanic, which contributes to the question involving who
may (versus who
must) complete the annual conditional inspections on EABs.
Regardless, the confusion amongst industry and the FAA on how to interpret the Operating Limitations as previously mentioned in this thread is out there, and can only be clarified by the FAA at a level above an individual FSDO, ASI, or DAR. We know that the FAA's intent is to allow Repairmen to perform conditional inspections, and that at the FAR level they may, come October 23rd.
How an owner/repairman/FSDO/ASI interprets these new rule changes with respect to an specific aircraft's operating limitations needs to be standardized and clarified by the FAA.
