Depending on which end of the Aileron is protruding, you either modify the A1006, or the A1007. I believe you can purchase an undrilled bracket from Vans also. To determine how much I needed to move the bracket, I elongated them a flew. After I determined the new hole position I drilled an undrilled bracket and installed it permanently. Laying a straight edge on the wing, you should be able to clearly see which aileron and which end is protruding above the training edge of the wing. Drop the aileron down till it's even with the trailing edge. Before you modify the aileron, make sure your flaps are both nested in the wing and at the same angle. This also can make a difference.
