planejus
I'm New Here
Today I constructed the pushrod for the elevator on my RV-7. when checking for the edge distance for the rivet holes on the rod ends, I realized that I don't recall doing that for the aileron pushrods that I fabricated a long time ago. Now I am wondering. From my build log I had primed the inside of the rods one day, and later riveted the ends on. I am wondering now If I ever pulled the ends out and looked at them after drilling, or just stuck rivets in them as I drilled. I don't remember measuring for edge distance on the end; just tucking them the the tube for a slight lip like depicted on the drawings. I really can't remember, but I want to know that my rod ends are secure. The ends are tucked inside the tubes just a little, but is it enough to have good edge distance on the rod ends that I can't see now. The edge distance on the tube is right at double the rivet diameter. I probably centered the rivets in the flat portion of the rod end. Does anyone have theirs out and have looked at them? Do these look like they are tucked in enough? Do I make new ones just so I know? Or am I being too critical? This is my first build and I am figuring it out. Thanks!
Here is a pictur from by build log when I drilled them.
