Vaccuum is good indicator of the proper combustion process at idle. Both timing and mixture will impact the level of vacuum produced by the engine at idle, as will valve issues, though usually to a larger degree. For example, I set my idle mixture by looking for the highest vacuum (lowest MAP). As I lean the mixture, MAP can go down by as much as 2"; Have seen more with really rich mixtures. My speculation is that #2 is going agressively lean or rich; Cause unknown. This substantially drops the combustion performance of #2 and this increases the MAP, which is additive from all cylinders. You can see the MAP change in perfect harmony with the EGT in his charts, which is what points me to a combustion efficiency issue. SOMETHING is causing combustion efficiency to drop.What's causing the MAP to pulse?
Go research from the 70's. Very common practice to use vaccuum gauges to troubleshoot engines. You will see several pages of various scenarios / behavior of the gauge and what problem it translates to. Vaccuum level is a fabulaous tool and provides many clues, especially idle issues. It is also great for identifying valve issues, even at higher power settings.
