Went flying again today, 3rd time in the air. Could not replicate events prior times. Took cowling off, no abnormalities. Today went flying to get an idea of GAMI spread. Idea was to fly at WOT, 8500 ft, 2400 RPM. Then turn around, fly WOT, 9500ft, 2300 RPM.
Flight at 2400 RPM was uneventful. Things went well. Got peak EGT, then it started to go down. Seemed like engine was fine until FF 10.5. "Might" have been able to get lower, but looked like I got peak EGT and it was decreasing across all cylinders, so didn't push it further.
Flight at 2300 RPM felt different. Got down to 10.6 GPH on FF again and noticed the same feeling I had before. Almost like the wind was hitting the nose wheel, causing a slight abnormal feel. It was intermittent. Same what happened as first post. There was never a loss of EGT/CHT. But at 2300 RPM, seems like I should be able to go lower than where I was at 2400.
Maybe everything was ignition related, still is? I can change plugs, easy. When would you pull the e-mags and send them back to get checked?
Link below is the engine data, for those interested. I think I understand what I see, but would appreciate more experience eyes. At around 10 min- 30 min, I was at 2400 RPM. Turned around, dropped to 2300 RPM until about 50 min. Then flew back to TUS.
https://apps.savvyaviation.com/flights/shared/flight/9993108/14f16af9-3b7d-430c-832e-efebb5644e36
