Thanks for the update, and where did you buy it ? Was it Summit?Ordered this for almost half Vans price. Fast shipping.
Yes, the Summit item is correct.
[td]
Stewart Warner 385B-F
[/td]
Is it the same sensor for both tanks? The rod just being bent the opposite way?
I am but not sure how that relates to my question.You’re on the RV-12 forum. Only one tank on the -12.
Just relaced the leaking fuel sender on my legacy RV-12 with a Stewart Warner 385B from Summit Racing. Same part number as the old one. The 385B is $28 vs $45 for the 385B-F. You have to bend the float arm to the dimensions listed in section 37 of the KAI.Yes, the Summit item is correct.
[td]
[/td]
