I broke down and placed an order for a new XO 0320 D2G engine from Vans. Just noticed that it has a scheduled ship date of 1/14/27. So, this has me thinking ahead...
Dimensionally the H is the same as the D, the Carb, FAB, prop bolts, hub, engine mounts, exhaust all the same. After that I'll need to change a few things.
How many things can I pre-order to save some money and time?
The fuel and oil lines will be 24 years old, it's time to replace. I made the ones on it now, but will go with new ones from TS Flightlines. Do they have a shelf life? Considering this will be a straight up swap to the Vans standard 0320 configuration can they be pre-ordered? The only question would be the location of the fuel flow & oil transducers.
Engine mount isolators, stupid expensive for a piece of hard rubber...
do they have a shelf life? Who has the best price?
I will need to order some baffle parts as the H accessory case is different. The front and rear baffles I had to modify, I think the rest should be OK.
The bottom cowl should remain unchanged. The top one can lose the distinctive H2AD bumps and I'll need to put the original oil door where it belongs.
I plan to do the Taper pin mod on the nose strut while it's off. Looking for anyone willing to loan me a reamer?
I'm sticking with magnetos, no real change for me. I just loose the Dual Bendix mag.
This is just a start, but looking for input on what I might be missing or should update...
I have no complaints about my H2AD, it has been a good reliable engine. It had 780 hours on it when I bought it. It was a factory Lycoming overhaul. Has always burned 1 quart every 10 hours. Oil analysis comes back with no problems. By the time I remove it, total engine time will be around 3100 hours. So, if anyone is looking for a running H2AD, this one will be for sale.
