backcountry
I understand Rotax now uses silicon hose’s on their IS engines. I’d like to replace the coolant hoses on my 912S UL engine. Looking for the best silicone hose pproducts and clamps for this project.
Thanks for the feedback. That helpsI understand Rotax now uses silicon hose’s on their IS engines. I’d like to replace the coolant hoses on my 912S UL engine. Looking for the best silicone hose pproducts and clamps for this project.
I did a complete write up in this thread, this is the meat of it;
5 year rubber alternatives
My 5 year is coming up. I already have teflon fuel and oil hoses. The things I see on the list that I will need are; 267-789, carb rubber flange, I see one from JBM that is cheaper, any reviews? 861-116, carb diaphragm, do these go bad? 922-250, coolant hose 17mm, where is the cheapest place...vansairforce.net
I get my silicon hoses from Pegasus Racing and use Oetiker pinch clamps (one time use).
Silicone Hoses by Inside Diameter | PegasusAutoRacing.com
If you are looking for a specific size of silicone hose, allow us to sort our inventory by inside diameter to help you easily find what you need. Check out our variety!www.pegasusautoracing.com
Seagull, I ordered the hoses in blue color that you referred to. The pictured here shows a red hose in the middle of a red hose.
The red part is silicone.Seagull, I ordered the hoses in blue color that you referred to. The pictured here shows a red hose in the middle of a red hose.
Question: due you know what the material of the red hose is.
Thanks for your help.
there is reinforced clear silicone that was rated for my use. it makes it easy to see bubbles.I noticed that clear silicone hoses are available. Would there been anything wrong with that?
You would be able to confirm and see that the liquid coolant was there.
You don't have clear oil hoses so you can see the oil....there is reinforced clear silicone that was rated for my use. it makes it easy to see bubbles.
but i did have a coolant issue that was trapping air and causing temp problems. i redesigned the overflow system [zero pressure system] with a manifold in the line at the highest point with a schrader valve in it so i can bleed air. clear hose was helpful.You don't have clear oil hoses so you can see the oil....
