jmiller007 Well Known Member Patron Aug 21, 2025 #1 Left wheel no issue. Right wheel? The valve stem is fighting me the entire way trying to get it through the inboard wheel half. Any tips or assistance? Super frustrated. Attachments image.jpg 1.8 MB · Views: 216
K Kyle Boatright Well Known Member Friend Aug 21, 2025 #2 jmiller007 said: Left wheel no issue. Right wheel? The valve stem is fighting me the entire way trying to get it through the inboard wheel half. Any tips or assistance? Super frustrated. Click to expand... Lubrication is your friend. Apply a little motor oil, KY jelly, or whatever you have at hand.
Dr_Dave_MT Well Known Member Sponsor Aug 21, 2025 #3 Do me a favor, flip the rim half over and come over the valve stem from the top.
Tony_T Well Known Member Patron Aug 21, 2025 #4 To do this job correctly you should remove the hub before installing the tire and tube. Also your tube looks badly cracked around the stem area. From Matco manual and page 35 of plans: I don't use the valve stem washer and nut. YMMV
R Ron B. Well Known Member Sponsor Aug 21, 2025 #5 Tony_T said: To do this job correctly you should remove the hub before installing the tire and tube. Also your tube looks badly cracked around the stem area. From Matco manual and page 35 of plans: View attachment 95607View attachment 95608 I don't use the valve stem washer and nut. YMMV Click to expand... I think what you see is part of the tire ( just excess rubber inside the bead).
Dr_Dave_MT Well Known Member Sponsor Aug 22, 2025 #7 Bruce said: Flip the tube 180 Boomer Click to expand... Yup…. Sorta like what I mentioned. Stem angle is 180 out of phase with rim.
