Larry DeCamp
Please bear with me. I am failing G3x run up test. Ross has advised just put in 97 top sensor and 88 bottom sensor. Still failing. My initial setup was ‘old style’ with timing light Resulting in @ 93 and 84. My question :
What does the pointer and flywheel marks mean. I turned the crank to tdc at case spitand set the pointer.Then set-he map to 10 up to 1200 rpm. The flywheel was marked at 10 btdc.
There is a 9 degree difference between Ross’s numbers and mine done as described above. Still fails run up vibration test. Any guidance greatly appreciated.
