Q - what method do people use for position setting for the flaps -
Digital level on the top or bottom surface ?
Or setup the level to parallel the flap cord line ?
We’re installing the ‘new’ PH flap motor & although motor (PH Av unit) is mounted, with shaft set at max travel for reflex position, when transitioning to full down flap it appears to be approx 40 degrees down. Is that ok?
TIA.
TIA.
