H [email protected] Well Known Member Sponsor Friend Aug 14, 2025 #1 Who has used the cascading circuit breaker panel? How did you mount it? Attachments IMG_0420.jpeg 1.6 MB · Views: 30
Chukill Active Member Patron Aug 14, 2025 #2 On my RV10, I mounted a panel (Cirrus part) on left sidewall at calf level. The panel is hinged and the wiring has a service loop to easily access the breakers
B Ben Ellis Well Known Member Sponsor Aug 14, 2025 #3 [email protected] said: Who has used the cascading circuit breaker panel? How did you mount it? Click to expand... This part is designed for an RV-8 and it gets screwed onto the console behind the right gear tower. There's a good pic of it in this post: https://vansairforce.net/threads/the-stein-wave.221619/ If you're intending to use it in another type of plane, then I suggest you let us know which type so you can get type specific advice.
H [email protected] Well Known Member Sponsor Friend Aug 14, 2025 #4 Ben Ellis said: This part is designed for an RV-8 and it gets screwed onto the console behind the right gear tower. There's a good pic of it in this post: https://vansairforce.net/threads/the-stein-wave.221619/ If you're intending to use it in another type of plane, then I suggest you let us know which type so you can get type specific advice. Click to expand... Nope, it is going in an 8. This is what I was looking for. Thank You very muchj!
