Pilot135pd
Sorry, I said 14 days and it was 17 days due to days off. I'm sure the days off helped make the training more complete than just 14 days. Ok, then, do you think that someone with 17 days...no wait, you already answered:First, to start with accurate facts, there is no 2 week course that is relevant to this discussion no matter how loosely you want to define terms. Based on the previous approved course at 120 hours it took 15 days of class, with federal guidelines that require days off it took 17 days. As to having the knowledge to doing a condition inspection, that's a matter of opinion or speculation. When I took the class there were a few "0 timers" in there, in my opinion some were competent at the and others were not. I spent 5 weeks in various types of aviation technical training last year and it included classmates that were just lowly LSRM like me up through IA. What I learned is that this 'some are competent and some aren't' idea applies to that entire spectrum. There were people fresh out of A&P schools that were completely clueless about GA aircraft. They were qualified to do your condition inspection, and could tell you all kinds of stuff about turbine engines but the Lycoming service info was going right over their heads. They were interested in learning more and I enjoyed learning along with them.
Something that you need to understand about the FAA perspective on safety, is that EABs sit below Light Sport on what they refer to as the 'safety continuum' (word search the rule for 'continuum' and you can learn more without needing to take my word for it). This concept plays heavily into a lot of the logic on MOSAIC. Light Sports are certificated and inspection is authorized at a higher level for LSAs than EABs. This may not seem intuitive or you could see it differently, but that's the data and structure that the FAA is working from. It is a tiered system were standard TC'ed aircraft sit above Light Sport, and Light Sport sits above EAB. This is why even a builder of an E-LSA had to get at least a 16 hour course and pass a test to maintain an aircraft that they build. What the FAA determined, after decades of data regarding safe LSA operation, was that the light sport criteria for inspection has a good track record and that it makes sense to extend the authorization to a lower tier of safety.
Making the judgement as to any individual being competent or not is difficult. If I think about the people I trained with, or the people I talk to doing professional maintenance, or the owners I listen to sharing their maintenance experiences it seems to me like it's all over the map. There are a lot of different motivations and experience levels out there. At the risk of going too far off on a tangent, consider that for an EAB the only requirement at all applies only to inspection. Anyone can do maintenance and modifications without any qualification at all. The 'trunk monkey' rule, says my 8 year old neighbor kid that has never touched an airplane can do anything they want to an EAB that anyone owns and if the CI is current it's legal to fly. If you're really concerned about safety risks that would probably be a much bigger hole to try and plug.
"When I took the class there were a few "0 timers" in there, in my opinion some were competent at the and others were not."
So my comments would be about those not competent, would an inspection by them be safe?
Then you mentioned "What I learned is that this 'some are competent and some aren't' idea applies to that entire spectrum. There were people fresh out of A&P schools that were completely clueless about GA aircraft. " , but all of those needed some experience to get signed off by the FAA to take the A&P tests, but that has nothing to do with the topic of MOSAIC so I won't comment on those.
"....they were qualified to do your condition inspection, and could tell you all kinds of stuff about turbine engines but the Lycoming service info was going right over their heads.", also nothing to do with MOSAIC but i think I'm I'm getting your point.
I guess your point is that lots of mechanics out there already are not the best so it doesn't matter if we add a whole lot more with 0, sorry, with 17 days experience to the mix because that won't make aviation less safe.
Then you said "...FAA perspective on safety, is that EABs sit below Light Sport..." and "...maintenance experiences it seems to me like it's all over the map..." , but your comment went into other things that are way beyond what my comment was about and if I address them it'll change the topic and I don't want to hijack this thread.
