bjohnson1234
Has anyone looked at/thought about using an exhaust waste heat recovery system with a thermoelectric generator as a "backup alternator" for electronic ignition? Seems like it should easily be able to generate enough power to run most electronic ignition systems https://www.acs.org/pressroom/press...opter-exhaust-into-thermoelectric-energy.html
I'm not sure how much a system like this would weigh (probably not significant?), but if it used the heat of the pipes themselves (https://www.psu.edu/news/research/s...nd-hot-surfaces-turns-wasted-heat-electricity) rather than the exhaust gases there would be no other performance penalty.
