Lexan or Plexi?
AeroDog
Friend
When looking at an older RV-12, is there an easy way to tell if the canopy is the original Lexan or later Plexi?
Jerre
Pour some fuel on it and see if it cracks? If it already has a bunch of cracks in the area near the fuel filler it is most likely the original Markolon PC.
Serial #79 here with the same as Mich and the rear window will crase really bad if fuel spills on it!
Are you asking about the rear piece?
Yes, rear. Mine is number 593 and came with Lexan. I switched to plexi because of the gasoline issue. One I'm renting is much older and the owner doesn't know which it is.
Jerre
The Lexan comes as a flat sheet that you curve to install. The Plexiglass is formed to the shape of the rear window. If you see crazing it is Lexan.
