I was one of the people affected by the flood. You can just barely see the wing of my 182 in the opening shot where they're driving by the hangar with the door laying on the Arrow. I'm pretty sure this plane was on the same field although I don't recognize it. I am on the west side of the field on one of the highest hangars on the field and got 5.5' of water–it just touched the trailing edge of the flaps. The hangars next to the Hendersonville runway got somewhere around 11' of water. The WNC Air Museum wasn't in the 500 year flood plane and got around 4' of water in it.
Each plane was affected a little bit differently. These engines and airframes are open to the elements at all times. There are at least two valves open along with the breather and other places for water to infiltrate. Some planes had a gallon of water in the sump. Others a few ounces. Most of the fuel tanks had water in them. Exhausts and cylinders were all full of water and would spew when you turned over the engines. Over the following weeks and months many of the engines got hard to turn over and had a rubbing sound. Make didn't seem to matter. Lycomings and Continentals both had the sound. "Pickling" didn't seem to change that either.
I spoke with several mechanics (including
@fixnflyguy) and decided to rebuild the 182. All the readily available electro-mechanical parts got binned: breakers, solenoids, switches, key switch, VR, etc. Amazingly one G5 survived (the other was older and didn't have a potted circuit board) along with the 430W, KX155 + GS, and several other avionics. The instruments didn't do so well with only the ASI and VSI surviving. Engine got "pickled" with as much oil as I could find until I could pull it around November to get overhauled. The interior got washed multiple times with water and simple green aviation. Even after 6+ washings I'm still finding silt to clean. Prop got sent off for overhaul and failed. Mag will get a 500-hour (it had 3 hours on it) and the surefly will get replaced since it doesn't spin anymore. Starter was pretty rusty along with the alternator and will probably get replaced. The entire fuselage and empennage was sprayed with CorrosionX.
I didn't find any real corrosion other than a bit of galvanic on the heat channels from the steel staples and some surface corrosion under the dash likely already there but made worse with the 50 year old foam soaking with water. I had one terminal destroy itself on the key switch and I'll need to replace the fuse holder for the surefly.
At this point I'm waiting on the case to get its 8130 so the engine can go back together. With any luck I'll be flying late this year or early next year.
There are already several flooded planes at Hendersonville/Johnson field flying including a RV10, a 172, a Yak, and a small fleet of ultralights. And I know of at least a dozen more that are in progress including a RV8.
