glider_rider
Did anybody place the GA35 GPS antenna on the top forward fuselage skin under the canopy? Any reception issues?
I often mount GPS antennas under the fiberglass cowl. Have also seen antennas located under the windscreen.Did anybody place the GA35 GPS antenna on the top forward fuselage skin under the canopy? Any reception issues?
I had exactly the same idea but my plans changed, I intend to place the starling mini over there.just installed this antenna on a doubler right behind the cabin fiberglass top. Good location and it meets the install restrictions.
There should be plenty of space for both.What I'm worried about is steel center cabin brace. Not sure if shadowing would be a factor?
Right, space is not a concern over there. At 100W Starlink mini is a relatively powerful transmitter and I have no idea if / how it would interfere with the GA35There should be plenty of space for both.
Any issue with high temperature under the cowl? I just got a GPS 175 with included GPS antenna. Per the specs, upper temperature limit for the latter is 85C (176F).I often mount GPS antennas under the fiberglass cowl. Have also seen antennas located under the windscreen.
Make sure the location is not shadowed by a metal component, ie. canopy frame, or too close to the firewall if under the cowl.
In years past metalic paints blocked the signal. Today almost all metalics use mica and doesn't interfere.
My maximum temperature reading at the antenna shelf located upper FWF under cowling is 125 F in flight and 135 F 5 minutes after shut-down. Florida summers. I've measured hotter skin temperatures behind my canopy. RV-14A with a IO390. 5 years no issues. GA-35 and 26.Any issue with high temperature under the cowl? I just got a GPS 175 with included GPS antenna. Per the specs, upper temperature limit for the latter is 85C (176F).
This pre-dates the GTN series. The GNC 4xxW/5xxW also had the 2meter minimum/10meter maximum limitation. (1.5dB loss minimum to 7dB loss maximum). A number of us just used inline attenuators instead of the roll of coax.If you are running something like a GTN-650 make sure you add enough coax to provide signal attenuation (see install instructions). This is a known issue with the GTN-650, the added line is needed to attenuate RFI induced into the GPS receiver when transmitting on the GTN comm. If you do this still watch GPS signals as you transmit on the GTN to verify satellite reception is not degraded.
I just installed this antenna on a doubler right behind the cabin fiberglass top. Good location and it meets the install restrictions.
Nope. I watched all the satellites go away on the display when transmitting on the GTN comm so yes, it was Comm induced RFI into the satellite receiver. I can only assume the cause was comm transmit harmonics falling into GPS frequencies, aggravated by the GPS antenna pre-amp.This pre-dates the GTN series. The GNC 4xxW/5xxW also had the 2meter minimum/10meter maximum limitation. (1.5dB loss minimum to 7dB loss maximum). A number of us just used inline attenuators instead of the roll of coax.
And it's not for comm interference; the gain from the amplified GA antennas exceed the WAAS receivers front-end for the L1 frequency. The 12th and 13th octave issue is still there, regardless of the loss introduced by the cable.
2 different issues.Nope. I watched all the satellites go away on the display when transmitting on the GTN comm so yes, it was Comm induced RFI into the satellite receiver. I can only assume the cause was comm transmit harmonics falling into GPS frequencies, aggravated by the GPS antenna pre-amp.
Yup, did the same thing with a remote antenna for my Trimble Flightmate -- mounted the antenna up on the center post in my Mooney 231.GA35 mounted as high as possible on the center windshield support with a diy mount in my slider -7A has worked flawlessly for the last 4 years feeding my GPS175 panel mount.
could you post a photo of the mount / installation?GA35 mounted as high as possible on the center windshield support with a diy mount in my slider -7A has worked flawlessly for the last 4 years feeding my GPS175 panel mount.
Haven's had any issues with heat. Have installed, and seen other installs with GTN and G3X antennas under the cowl. No one has had issues.Any issue with high temperature under the cowl? I just got a GPS 175 with included GPS antenna. Per the specs, upper temperature limit for the latter is 85C (176F).
I had that installed under the cowl on my 6A. I had at least three loss of signal issues with that configuration. Finally moved it to the top of the plane and has been problem free for the last 1200 hours. I fly a fair amount of IFR, so was unwilling to accept the risk any longer. My GRT GPS antenna is still under the cowl and has never had any problems.Haven's had any issues with heat. Have installed, and seen other installs with GTN and G3X antennas under the cowl. No one has had issues.
Probably depends on installation. (shadowing, length of antenna cable run, etc.) It's easy to look at signal strength cowling on and cowling off rotating 360 degrees. I saw zero difference cowling on and cowling off before and after paint (metal flake paint used) and temps I monitor. (See post 10) Never an issue with signal loss.I had that installed under the cowl on my 6A. I had at least three loss of signal issues with that configuration. Finally moved it to the top of the plane and has been problem free for the last 1200 hours. I fly a fair amount of IFR, so was unwilling to accept the risk any longer. My GRT GPS antenna is still under the cowl and has never had any problems.
From my reading here over the years, I am definitely not the only one who has had issues.
I agree that most people get away with it. But when I see statements like no one has issues with it, I think it's important that people with problems speak out.Probably depends on installation. (shadowing, length of antenna cable run, etc.) It's easy to look at signal strength cowling on and cowling off rotating 360 degrees. I saw zero difference cowling on and cowling off before and after paint (metal flake paint used) and temps I monitor. (See post 10) Never an issue with signal loss.
