390-EXP oil drain access without removing the lower cowl
Halleffect
The oil drain on the EXP sits right above the forward part of the lower cowl closeout. Making the close-out two pieces allows easy access to the drain with the cowl in place.
Sorry but I can't think of ANY reason to drain the oil with the cowling in place. If it's time to change the oil, it's time to inspect everything FWF!
We got a thumbs up button with the new version/upgrade, it is time to have a double thumbs up button as this is a good example to give one.
IF you hover over the thumbs up like, there is a smiley face with hearts for eyes. Typically that is what I use as two thumbs up.
