Cheapo P-Mag Monitor and DataLogger
petehowell
I got some help from my old friend Brantel and put together a quick and dirty PMag monitor and SD card datalogger. It even creates a WiFI network to let you manage and download data files.
A cheap yellow display ESP32 board($12) and an RS232-->TTL ($2) converter board are all you need. You need some Arduino code, but I know a guy that will share for a beer(the code is ugly). TBH, the whole thing is not pretty, it's not elegant, but it works - and it's less than $15. So it's a lot like me...................
AP1GczO0U1XAs4oMYqNITELaEmLNvkjs4fOUF44rwyMgafdcfm0xOakjcJG4HmWhsQnnQVEMB91k1JSiyiQIlzkhufUnZsmeXzv43ebvkkJT-eE8GNboceTzmgIcPwR4mlDo2eUYvZjg8OgB2MwoxBNcEY47oQ=w400
It will read Advance, RPM, MAP, Volts, and CPU Temp once a second. The MAP and temp data is pretty much junk - but I think that is on me and not P-mag.
The RPM and advance data makes a nice 2-axis graph - this was a sightseeing flight down the Mississippi:
AP1GczP-emihas5VVzb7lOokFhrh8tSl5oP1-1QJ6NQqpFdP-wzRU7xjo1_zeOePYdMHP1pwue-A3gueTv2XxDJiW7OSnkCxRdnijQbuPkRgeV06h7q1ePB0-xM36gn0-8HRpC1G4n-U0uVrD59ktzg8IVivAw=w1000
Next step would be to marry this data up with he Dynon flight and engine data.
That….is awesome Pete!! I need four of them…..
(Actually, the coolest thing about the post is that plot - it really shows what goes on throughout the flight with the P-Mags!)
Well done, Pete.
I have done something similar, and I added a 2-channel oscilloscope function to display timing in-flight. Not yet ready for prime time, though. I hope the Hartzell acquistion of Emagair doesn’t end the technical support I am getting from Brad.
Keep up the good work! I think you've been on VAF for 20+ years.
