I attempted to power my system up for the first time yesterday and I experienced a problem with the PPS. The pps would not allow battery power to flow to the main bus (VPX-pro) when the master switch was flipped. We made several checks to establish continuity from the master switch to the PPS pin 7, to the ground from the switch and from the PPS, made sure the we were getting proper power to the PPS and confirmed that the power was not being allowed to the “main bus” post on the PPS. I even de-pinned the PPS connector and stuck the male pins for power and ground into the port on the PPS. Nothing! I called vertical power and explained it to them, they agreed it seems that there may be an issue inside of the PPS. They agreed to have me provide me an RMA to send the unit in to be diagnosed. The unit is brand new and still under warranty. Has anyone had the same or a similar issue?? Is there a trick I’m missing?? Also to verify that the VPX was working, vertical power confirmed that I could attach the + battery cable directly to the VPX post and confirm it works. It worked and ran perfectly fine. The good news here is all of my wiring was perfect and I had no issues anywhere else. Thoughts?
