I’ve got a Cleveland 10-9 caliper and a 10-30 Cleveland master cylinder on the pilot side and a Matco MC-4A on the co-pilot side. I rebuilt both master cylinders on the left brake. I’ve bled from the bottom up and have pulled a vacuum on one occasion. The brake isn’t sponging, it just has excessive travel (2”). The right side only travels an 1/8” before it grabs. I noticed after I bleed it, it grabs after 1/8” travel. It even held for a few hours. Next day the 2” travel is back.
The other thing I noticed is it seems the piston on the caliper seems to retract back about a 1/4-3/8” instead of the pads lightly dragging like the right side. I’ve spoken to Cleveland and they said to make sure the peddle is not restricting the master cylinder from fully extending which would case the check valve from fully closing. I removed the bolt at the top clevis hoping that was the problem but the peddle moved forward another 1.5” proving it was restricting the full extension of the master cylinder.
Has anyone had this happen before and know what fixed it or the cause?
Everything would point to the master cylinder but after rebuilding both of them, which I’ve rebuilt a few would any problems, and swapping out both to the pilot side, it’s unexplainable
