Flyleds are made down under, so there was no international shipping
Nice work on that skirt Paul.
Mine were made using aluminum, and don’t fit the contour as closely as yours… the resultant being water getting sucked in when flying thru wet atmospheric conditions. I’m still working on the most suitable seal.
Awesome looking work Paul. Next time I need my 6A painted, it’s headed your way! Of course, there’s the small matter of the ferry flight from San Jose California to Western Australia, but I’ll figure that one out!Temperature was just right this morning, 22 degrees C and relative humidity 55%. I got the paint mixed and filled the cup and had a problem with the gun leaking. First time that this ever happened!
This wouldn't be an RV project if there wasn't a challenge and a problem to solve! Gun has been emptied and cleaned (small piece of debris had dislodged and obstructed nozzle) and continued on with spraying the top and sides.
Once the paint had hardened sufficiently, I could pull off the masking tape and paper. It's poppin, I'm kinda happy! Gotta like red...
View attachment 81645View attachment 81646
Thanks Warren, you have sharp eyes, and another pair is always welcome! The SB was done some time later after Vans sent the finger patches and a local TIG welder put them on the pedals.Paul, I noticed in an old photo that this service bulletin was not completed.... https://www.vansaircraft.com/service-information-and-revisions/sb-99-06-1/
The paint job looks great!! Not many have the guts to paint their RV.
The cowl, and the rest of the paint job look awesome. Love the color. Could be Porsche Guards Red.All of the external painting is essentially complete now but when I went to fit the cowls there was a noticeable mismatch between the paint finish and the rest of the fuselage. There was more orange peel on the cowls than I liked and this is probably because they were painted quite early on, before I had some more practice and experience from painting the rest of the airframe. The cowls would probably be passable but since the paint booth was still set up I sanded back the cowls and re-sprayed them. This added two days to the project, which doesn't seem like much on top of 32 years.
I'm now finishing off details in the engine bay and cockpit before moving the fuselage out to the hangar and putting on the wings.
Pics of the cowls after re-painting:
Hey Paul,A bit more progress... by now it's nearly the middle of May. I extended the hangar by making a Tee in the back wall in order to fit the RV and then wheeled it over from the workshop. It looks so small in there without the wings on, behind the mighty Foxbat (normal TAS 75 knots).
The engine crane is lifting the fuselage just enough to take the weight off the main gear and remove the wing main spar temporary stub.
My teenage son helped me to put the left wing on and it was as expected, i.e. a bit of a battle to slide in the spar and align the holes for the pins.
The next step is to fit the right wing and then the splice plates and the close tolerance and other bolts.
A couple of buddies came over to the farm strip in our club RV-9A to check on my progress, and that helped with motivation!
Absolutely Paulenjoy the peace
Are those hinge brackets shifted horizontally? Left/right?I'm continuing on with the remaining "1% work" final assembly and have so far fitted the wing fuel tanks and connected their lines, as well as the ailerons, the Flyleds wig-wag landing lights and the wing tips. The control columns and main pushrods have been installed and the elevators are mounted on the horizontal stabilizer.
I hit a couple of snags today when trying to fit the rudder. There was interference between the bolts that attach the vertical stabilizer and the fairing on the bottom of the rudder. The AN4 bolts are installed per the plans with the heads facing forwards but they will need to turned around to prevent the tails from contacting the rudder and preventing full travel.
Another issue is that the rudder rod ends did not align with the hinge brackets on the vertical stabilizer and unfortunately it's not a matter of adjusting the rod ends to correct the problem. The issue is that the mounting plate between the vertical stabilizer and HS spar needs to be replaced and re-drilled to bring the VS hinge brackets into perfect alignment. Something must have shifted or been clamped incorrectly when I previously drilled the holes for the attaching plate, and so the bolt holes are out by 3/32".
This has all been a bit slow going and frustrating to be honest, partly because there is limited space for access to see and fit the bolts and washers and nuts etc. So I've just been working away at it and taking "breaks" to do some outside yard work in the fresh air and enjoy the peace.
The hinge brackets are in the correct position horizontally, i.e. they are aligned with the centre line of the VS spar channel. The mis-alignment in the fore-aft direction is a result of a slight bit of flex in the VS spar when I drilled the mounting plate that attaches the fwd spar of the VS to the HS. This put the centre hinge bracket out of alignment by about 1/32" in the fore-aft direction. If the 4 bolts are removed and the VS is flexed back very slightly then the brackets can be perfectly aligned.Are those hinge brackets shifted horizontally? Left/right?
Thanks Dan, I really thought it would be finished by now and it appeared there would be only a couple of weeks work to re-assemble everything after painting, haha. There was the bit of extra work to extend the hangar and since then the RV assembly work has been slow going because of limited access e.g. to reach and adjust rod ends and get the little washers in there. Umpteen have slipped out and dropped down to be fished out with a magnet. If I try to rush, it just ends up taking longer!Absolutely Paul
What a great picture... and mindset, which I sure should apply to myself more, just ask my wife (not...).
Ok, I'll think about it later (...), as for now, and specifically you, plough ahead, I really hope you'll be rewarded to the fullest with that labor of love, sure close to the goal![]()
I may be missing something but this fore amd aft misalignment can't be adjusted by moving the heim joints in and out by screwing or unscrewing them a bit? Now I'm just curious I guess.The hinge brackets are in the correct position horizontally, i.e. they are aligned with the centre line of the VS spar channel. The mis-alignment in the fore-aft direction is a result of a slight bit of flex in the VS spar when I drilled the mounting plate that attaches the fwd spar of the VS to the HS. This put the centre hinge bracket out of alignment by about 1/32" in the fore-aft direction. If the 4 bolts are removed and the VS is flexed back very slightly then the brackets can be perfectly aligned.
If the hinge brackets on the spar are mis-aligned due to the spar being "bowed", then compensating by adjusting the heim joints on the rudder will result in those hinge points being mis-aligned "bowed" also. I have been using a string line stretched through the centre points of the heim joints, and then separately also the rudder brackets, to check that they are in a perfectly straight line. Then, when the rudder is fitted to the VS the bolts should slide in without any difficulty, because all of the hinge points are aligned about the same axis.I may be missing something but this fore amd aft misalignment can't be adjusted by moving the heim joints in and out by screwing or unscrewing them a bit? Now I'm just curious I guess.
Spar being "bowed", AH, that was not in my mental equation. That is an issue.If the hinge brackets on the spar are mis-aligned due to the spar being "bowed", then compensating by adjusting the heim joints on the rudder will result in those hinge points being mis-aligned "bowed" also. I have been using a string line stretched through the centre points of the heim joints, and then separately also the rudder brackets, to check that they are in a perfectly straight line. Then, when the rudder is fitted to the VS the bolts should slide in without any difficulty, because all of the hinge points are aligned about the same axis.
