TRANSPONDER AND ADS-B POLICY/PROCEDURES• FAA Policy Guidance for Transponder and ADS-B operation for formation flights is as follows:• AIM Chapter 4, Section 1, paragraph 4-1-20g.3 states:When participating in a VFR formation flight that is not receiving ATC services, only the lead aircraft should operate theirtransponder and ADS-B Out. All other aircraft should disable transponder and ADS-B transmissions once established within theformation. NOTE – If the formation flight is receiving ATC services, pilots can expect ATC to direct all non-lead aircraft to STOPSQUAWK, and should not do so until instructed.3• FAA Advisory Circular 90-114B, ADS-B Operations, dated 12-30-2019 states, in paragraph 4.3.1.3:Formation Operations. ATC uses established transponder and ADS-B transmission procedures when participating in formationoperations. Per the Aeronautical information Manual (AIM) paragraph 4-1-20, if the formation flight is receiving ATC services, pilots can expect ATC to direct all non-lead aircraft to “STOP SQUAWK”, and should not do so until instructed. For visual flight rules(VFR) formation flights not receiving ATC services, ATC directs that only the lead aircraft should squawk the assigned beacon code(1200). All other aircraft should disable transponder and ADS-B transmissions once established within the formation.• Based on the above FAA policy guidance, the FFI transponder and ADS-B guidance is as follows:• Leads will brief, for all formation flights, that all wingmen will turn off or disable both transponder(STBY or OFF) and ADS-B transmissions (OFF or Disabled), prior to check-in and taxi, and for theduration of the flight.• Leads will squawk the appropriate transponder code and transmit ADS-B for the flight.• It is FFI policy that all aircraft are “established in the formation” upon engine start, and remainestablished in the formation throughout maneuvers such as takeoff rejoins, in-flight pitchouts andrejoins, and extended trail maneuvering.• At tower-controlled airports, Leads should request that “all wingmen stop squawk and ADS-B”during their first transmission to Ground Control. At non tower-controlled airports, in order toestablish good habit patterns of compliance with this ATC requirement, Leads may direct this uponinitial formation check-in, if desired, to support the pre-briefed (and required) mode of operation.For example, “Falcon Flight, squawk STBY, ADS-B OFF”.• If a flight starts operations at a non-towered airport, or does an airborne rejoin while not utilizingATC services, then subsequently utilizes ATC enroute or terminal services (for example, flightfollowing, or a recovery as a formation to a towered airport), Leads should request that “allwingmen continue to stop squawk and ADS-B” during the initial check-in with the first ATC facilitycontacted.• For situations in which a flight launches as a formation, then subsequently breaks up and recoversas individual aircraft, Leads
