db1yg
Fuel Flow fluctuations
Need some help on where to start trouble shooting a fuel flow issue.
My fuel flow (red cube) was showing some unusual flow rates in my morning flight today. This is an IO340 Continental Titan engine (8:1 compression) with the fuel pressure pick up at the mechanical pump outlet and the fuel flow transducer just prior to the flow divider connected via a 90 degree fitting using the Aircraft Specialty mount. This set up has provided 130 trouble free hours to date.
I had leaned to my normal 25 to 40 degrees lop and after a few minutes the flow indication went from 7.2 gph (which is normal) to 5 gph and then fluctuated +-1-2 gph. Normally I see a steady reading with maybe a 0.2 gph fluctuation. Fuel pressure was steady as was egt and engine performance. The OAT was unusually hot at my cruising altitude at 75 degrees and the cht’s in climb had to be managed (#4 hit 390 prior to level off) so there was considerable heat in the cowl. Additionally I am running a 50% blend of 100LL with alcohol free 87 octane pump gas.
My thoughts on what could be the cause:
1. Fuel flow transducer is failing or I have a ground issue?
2. The unusually hot temperatures along with the 50% pump gas was releasing vapor at the 90 degree outlet from the fuel flow transducer.
Since I have never had this issue prior and the temperatures were unusually high today I lean toward cause #2. The problem with this conclusion is that the fuel pressure was not fluctuating, egt’s were steady, and performance was not affected.
My current plan is to fill with 100 LL and see if the issue goes away.
Comments—thoughts?
db
Comments—thoughts?
db
