What would cause the 'knurling' on this center ring of the #1Millennium Cylinder? About 100 hours on the professionally rebuilt Lycoming E2A 160 hp and always run LOP with mo gas. Synthetic oil changes prior 40 hours. Blackstone reports fine. Borescopes decent with slight scoring. RV4 so cool cht's. Other three Millennium cylinder compression tests always showed 78 or 79. This #1 cylinder showed 78/76/70/66 and the consensus was to pull it in case the decline was due to a cracked or broken ring. The highly regarded local engine shop measured the cylinder at .005" out of round. They had not seen a ring like this before. No reply from Superior so far.
