Tx. Yes, I have. I've worked with Don at AFP, with a couple rounds of restrictor replacements. From stock 0.028s to two at 0.0245, two at 0.025, one at 0.0255 and if memory serves, one at 0.026. I think his comment was something to the effect of "pretty good, about as good as we're going to get". I know that some see spreads as low as 0.1 gph. My GAMI spreads may be affected a bit by fluctuating FF indications--slow oscillations of +/-0.2gph, which can make it a challenge to know when individual cylinders "really" peak. According to Savvy, they see that a lot with IO-540s, although they don't know why. My FF sensor is in the tunnel, upstream from the engine-driven pump (not ideal, but also not uncommon)--I can't help but wonder if that contributes to the fluctuations. Induction leak tests are negative. I repeat those periodically as a simple way to check for intake gasket degradation in between oil changes or other maintenance where I remove the cowl. In the end, I lose enough speed as I lean below 10 gph that I don't really want to run there. EGTs match up well at that FF, so working it further may be a low ROI activity for me.
