For those of you that have an A/C system installed with the condenser scoop on the belly, have you had any issues with oil out of the breather tube collecting on the coils? The A/C system I'm installing (SFSA) has exhaust pipe extensions but I'm wondering if an oil separator is also needed. I wasn't planning to install an oil separator so if I do, I'd want to use one with a catch tank instead of returning it back to the engine. I can imagine oiling up the condenser coils would reduce the efficiency over time and may be hard to clean.
-Bob
-Bob
