Generally that's what I do when buying locally. But, I'm in Canada so shipping isn't cheap. Would be almost as much as the parts.They're small and light so return shipping will be cheap
Probably a good idea as this appears to be an ongoing problem.In addition to the rebuild kit, order a new shaft. They leak due to side loading of the shaft which wears the seal. A new seal will not last as long as it should unless the shaft is replaced. Some have had good luck with polishing the shaft but for my money I just replace it
Not sure. Just call Matco. They will get you what you need.Probably a good idea as this appears to be an ongoing problem.
Is this an MC4 or MC4A? Part # for the shaft?
Thanks Tim
Ive called and written an email. Still waiting for a response. Once I know it will be another week to get the parts.Not sure. Just call Matco. They will get you what you need.
If you don’t get an answer, i will go back to me acs order archives. I thought it was mc4, but just can’t recall.Probably a good idea as this appears to be an ongoing problem.
Thanks Tim
Still nothing back from my phone call or email. Not that great of service.If you don’t get an answer, i will go back to me acs order archives. I thought it was mc4, but just can’t recall.
Thanks, I do appreciate the help. 60 hrs ago I changed the seals and its started again. I didn't see any scarring on the shafts but I will change them as well. Its such a pita on working under there.MC4
Part# 06-02998
MFR Model# MCMCRBD4
This was the rebuild kit I ordered and it worked
Thats odd. It is pretty straightforward to reassemble, but wonder what would cause that. My shafts looked decent, but I chuck them in a drill and hit with 600 grit. Recommend you try that. Also make sure you do not assemble it dry. Each piece of rubber needs a bit of fluid on it when reassembling. You can trash the orings in a few strokes when dry.Thanks, I do appreciate the help. 60 hrs ago I changed the seals and its started again. I didn't see any scarring on the shafts but I will change them as well. Its such a pita on working under there.
Thanks again
Tim
