Yes, using 663 washers on both sides. As far as being positive they are 20's - no, I'm not positive. What I am positive about is they are the only bolts that could be 20's. What I mean by that is all other bolts are accounted for. Sooooo, if they aren't 20's, Vans sent me the wrong length. Hope that makes sense. I'll remove one of them and measure it.Are you sure they're 20's? Using the correct 0663P washers?
PS did you clean the powder coat from the surface under the bolt heads to get a good ground to the fuselage?
Thanks, it's in my Spruce cartOne of these AN bolt gauges comes in very handy, easy to check every bolt. I have found a bag or two that didn't have the correct length bolt.
AN Bolt Gauge | Aircraft Spruce ®
AN Bolt Gauge Automatically sizes all AN bolts up to 5/8 diameter and 5 inches long.www.aircraftspruce.com
There isn't enough material to remove on the lower inner mount tubes. I ordered some AN6-22A bolts. Those should work.That’s definitely to short - you want 1-1/2 threads at least - but more than three is excessive. Is there room to grind off any engine mount tube under the bolt head? ...Engine mounts frequently have minor tolerance issues that require a little grounding or slightly longer (or shorter) bolts.
Actually, the plans call for 632 washers on the back of the upper bolts only. The lower bolts use 663 washers on the back. All the bolts have 663's on the front...Next for the 14 there is a note to use washers on the upper bolts only, why?
I seem to remember someone (Scott?) saying the RV-14 mount was designed and attached differently to the other mounts.Is there a reason for the nut to be placed in that location?
For ease of inspection, wouldn't it be better if the nut was on the engine side and a castle nut used...... Like the RV6.
Thanks for confirming this!Brian,
I had the exact same issue on my -14. Purchased longer bolts and moved on.
I never had that problem with the 20A bolts. I did have that same isssue with the lower outside bolts though, so I added a .032 washer on those bolts. If you take a nylok and thread it on to those AN6 bolts you’ll find that when the nut is bottoming out on the grip, there’s only about 3 threads showing. If you have 3 threads showing on yours, it’s very close to giving a false torque reading because you’re tightening against the grip and not the stack up.lower outside bolts (AN6-22A) have 3 threads showing.
This is very helpful Todd. Thank you! I will take a closer look at the bottom outside bolts to see exactly how many threads are showing.I never had that problem with the 20A bolts. I did have that same isssue with the lower outside bolts though, so I added a .032 washer on those bolts. If you take a nylok and thread it on to those AN6 bolts you’ll find that when the nut is bottoming out on the grip, there’s only about 3 threads showing. If you have 3 threads showing on yours, it’s very close to giving a false torque reading because you’re tightening against the grip and not the stack up.
Came here to say that. One of the best purchases I made, unfortunately after build.One of these AN bolt gauges comes in very handy, easy to check every bolt. I have found a bag or two that didn't have the correct length bolt.
I ordered AN6-21A bolts as well as the AN6-22A (and a few other assorted sizes to have on hand for future issues like this). Thanks for the head's up. I will be paying special attention to possible "bottoming out" issues after seeing how short the threaded section is on these bolts.I think you could use a .032" (NAS1149F0632P) washer on the fore and aft sides and the 20A bolt length will be fine.
Also, be careful if you ordered AN6-22A bolts, they may be too long and you will "bottom out" the nut against the shank of the bolt. Maybe you should have ordered AN6-21A bolts???
